please hlelp, wont start - Ford Powerstroke Diesel Forum
Old 06-07-2012, 06:23 PM
2008, f-250, 108k
took the truck to local lube shop today to have the fuel filters changed. now it wont start.
they believe it is due to leaking fuel/water drain leaking.
I had it towed home. I removed the fuel/water seperator on the pump and found a torn O ring. that is simple.
I tried to remove the side cover on pump, because the filter housing is full of crap "a black pasty/sandy substance" and needs cleaning. I can not figure out how to remove the lines. 2 have blue tabs on them. ??? and 2 will need a tool. whats the tricks??
after i get it back together, whats the deal with getting it to start?? i called my dealer and he stated to just keep trying???
whats bad is, i voluntered to help my local rotory club with an off shore fishing trip with some guys this weekend. crap, they are depending on that.
thanks, dale
Old 06-07-2012, 06:28 PM
Clean the inside of the water separator with brake cleaner or carb cleaner. You need to cycle the key to the on position 6 times before trying to start your truck. Hopefully they didnt starve the high pressure pump and burn it up. Good luck.
Typed with my thumbs from my Autoguide app.
Old 06-07-2012, 06:31 PM
After changing fuel filters u have to cycle the fuel pump at least 5 times before starting , turn the key on without cranking, leave on for 30 seconds, turn off for almost a min, repeat that 5 times, then try to start, U have to get all the air out of the lines.
Just a thought, do u know what brand fuel filters they used??
Old 06-07-2012, 06:40 PM
OK, how can I tell if they damaged the HP pump?
they used thier brand of filter. after the truck wouldnt start, they called the local dealer. they stated it needed motorcraft. they took the others out and put in motorcraft. still wont start.
Old 06-07-2012, 07:30 PM
Air in a diesel fuel system is bad. You need to bleed the air out.
Old 06-08-2012, 03:45 AM
what about the bleed valve on the fuel cooler pump? what is that for?
Old 06-08-2012, 04:33 AM
You can also bleed it through the banjo bolt up top (I wrapped a towel around it) or through the little air valve on the cooler. After I changed my fuel filters I had a no start situation and had to bleed it this way... be prepared to get covered in diesel though.
See First Fuel Filter Change - Cant Start
Old 06-08-2012, 07:43 AM
Ok, I took the lower pump off to clean out the junk. Im comfused about a couple of pieces. can someone tell where they go? thanks
Old 06-08-2012, 07:50 AM
FYI.... guys that work at local lube places are retarded employment rejects that got fired from the gas station,,,, i would never let them touch a vehicle of mine...
Old 06-08-2012, 08:38 AM
Also came across a air bleed vid:
