Motor Blown/Broke something - new engine suggestion - Ford Powerstroke Diesel Forum
Old 06-05-2012, 08:39 PM
2008 F-450.....
The idiot techs (yes 2 different techs with 2 separate screw ups) at my normal lube shop screwed me. One didnt fully tighten the oil pan plug and the other screwed around with with my coolant.
needless to say, my engine seized about 50 miles down the road....and I walk away with a 15,000 dollar check to keep my mouth shut.
So....I need replacement suggestions.
I guess I should let you know that I run a hotshot outfit.....normal load of about 10k pounds on a 38 foot gooseneck trailer weighing about 7k pounds.
Whats up with Black Mamba Engines? I keep hearing all kinds of good things about them. Im a nazi when it comes to general maintenance. Oil changes every 5k miles, fuel filters every 20k. I make sure my moneymaker is well taken care of.
I dont know much about upgraded performance...and it would sure be sweet to be able to haul over the 26,000 pound (or so) max tow rating that ford gave me.
If I wanted to stay within a 10k budget (to get everything done.....new engine, installed, with warranty) what would you guys recommend?
Old 06-06-2012, 05:20 AM
Your best bet would be to check with blackwater engines and also rudys diesel performance and see who gives you the best price.
Old 06-06-2012, 07:49 AM
Not much of a general maintenance nazi if you're replacing fuel filters every 20k.
How did you get the lube shop to pay you?
Old 06-06-2012, 08:05 AM
Feedback Score: 5 reviews
^^That and the making sure she's taken care of comment kinda contradicts the thread title
OP: I don't know anything about the Black Mamba engines but I would recommend deleting your EGR coolers, and DPF, installing an aftermarket Intake like AFE or S&B, and getting a H&S tuner
Old 06-06-2012, 12:08 PM
Sorry to hear that, how exactly did the engine blow? No oil? No collant?
Old 06-06-2012, 01:07 PM
Originally Posted by CrimsonLogistics View Post
2008 F-450.....
I'd figure out what is wrong with yours first. For $10k you could build one hell of a truck
Old 06-06-2012, 09:02 PM
Well I think fuel filters should be done every 10K possibly sooner depending on fuel. Anyway I think you should rebuild your current engine, keep the block and heads, bore the block as needed, massage the heads, replace the other hard parts, rods crank (stroker crank, Im sure someone makes one) pistons cam etc etc, Fully forged & balanced. Also do your own oil changes, saves money and you make sure its done right.
Old 06-07-2012, 07:20 AM
im calling BS post....
Old 06-08-2012, 12:30 PM
Dont Mess With Texas!
I would suggest a new Lube shop of do it yourself I would recommend getting in touch with Rudy's Diesel Performance they could get you a nice setup in that price range im sure.
Old 06-09-2012, 10:26 AM
Warheads on Foreheads
Oil at 5K and fuel filters at 10K, doing it yourself is the only way to ensure its done right. No punk teenage kids at a lube shopnare ever going to work on my rig.
Or you could put in a 5.9 in stock form just for reliability.
