Hard knocking when steering - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-05-2012, 09:18 AM Thread Starter
As the title says, I feel/hear a hard knock when I steer the truck. Usually at speeds less then 10 mph, say around a corner, or pulling into a parking spot. Ive looked up under the truck for any loose parts, and even asked the guys at the tire shop to look around when they were rotating the tires, but nothing. I really dont know if its part of the steering controls or maybe the coilovers adjusting the the weight each time I turn, regardless, its worrying me - more to the point of, I dont want to be driving down the street and the front end fall off!
Anyone have any ideas or similar problems?
Note: the truck will also make the sound when I put the truck in reverse to back into a spot.
Thanks!
2008 F250 KR
DDM 5000K 35W HI/LOW and Fog, Interior LEDs | Rough Country 3" Lift with Top Gun 1" spacer and 5" rear solid block | 35x12.5x20 Toyo Open Country M/T | H&S Mini Maxx
UofMF250 is offline
post #2 of 3 Old 06-05-2012, 06:02 PM
If its 4x4 check the front axles where they connect into the front end housing. I had one were those seals tore and the axle had some play in it. It had vibrations in steering and some noises over bumps.
Sent from my PC36100 using AutoGuide.Com Free App
08 f250 6.4 all stock
nettles516 is offline
post #3 of 3 Old 06-06-2012, 07:28 PM Thread Starter
Ill check that, but there is no vibration in the steering or over bumps just turning...
2008 F250 KR
UofMF250 is offline
