Driver side blend door motor
Where is the driver side blend door motor located? I took the dash off Friday and found 3 easily visible motors, 2 of which weren't the part I had ordered ahead of time so I had to run out the next day and get.
Anyways, I replaced all 3 and the driver side issue persists. Is it inside the heater box? Here are the ones I replaced and a large overview behind the dash. I documented the whole dash removal with pictures which I'll post some time, not that hard now that I know how to do it. Was so pissed afterwards though.. Last edited by reighnman; 06-04-2012 at 11:54 AM. |
Sorry not help here (but a free bump). Please do post up pics/ instructions on how to remove the dash though.
Nobody knows
i just resorted to turning up the stereo
How does that warm you up when your vents are blowing cold in winter??
oh, i thought you were referring to the little banging noise they make opening and closing in a f-d up fashion..... chronic noise //rattle in dash associated with them.......ive never been able to turn my stereo up loud enough to stay really warm in the winter....you should indicate what your problem is then you would probably get more helpful info... no air flow? air flow with no heat?
The problem is I can't find the driver side blend door motor, hence why I asked where it was
But I could see how it was misleading
been several post on here about trying to remove the dash,, you are one of the first that have done it, so im fairly certain that you know have more visual knowledge of what it looks like behind the dash than most on here,,,, that is why i think no one has chimed in to point you in the right direction....
Yea, suppose I need to find a ford tech or a assembly manual hmm
Actually just found it and yes it's buried..
Removal and Installation: Remove the heater core and evaporator core housing. Remove the floor duct screw. Remove the floor duct. Disconnect the LH temperature blend door actuator electrical connector. Remove the 2 LH temperature blend door actuator screws. Remove the LH temperature blend door actuator. To install, reverse the removal procedure. __________________ Looks like in this vid he was able to get to both of them without removing the dash? Last edited by reighnman; 06-08-2012 at 09:03 AM. |
