Adding oil temp gauge, where to put sensor? - Ford Powerstroke Diesel Forum
Old 06-03-2012, 05:27 AM
I'm thinking of adding an oil and coolant temp gauge in a pillar mount. Can any of the tech's out there tell me where the best as well as easiest place would be to install the sensors? Thanks.
Old 06-03-2012, 05:34 AM
You can run your ECT from a drain plug. It's underneath, backside, driverside. It's just a block drain plug. Your EOT can run from a billet oil filter cap that has been tapped for a sending unit or I believe the oil cooler or oil sending unit
Old 06-03-2012, 05:35 AM
I have mine installed in a billet oil filter cap.
Old 06-03-2012, 05:44 AM
Wow, thank you both for the quick response and good info.
Term, where did you get the billet oil cap? I find some for the 6.0 but not saying for the 6.4. Are they the same? Thanks
Old 06-03-2012, 06:18 AM
Feedback Score: 10 reviews
ol38y , yes , the oil cap does fit 6.0 and 6.4 , but you should just be causious when buying the billet cap , Just make sure its compatiable with the motorcraft/racor filters (or the proper set up inside ,so the filter will clip in properly)
Old 06-03-2012, 06:28 AM
Thanks d23, Rudy's has them online. I'll call them in the am. I see Amsoil has them as well. I may call them too. Thanks again.
Old 06-03-2012, 06:42 AM
Sure, you can buy an H&S Mini Maxx and have your temps displayed in one convenient location.
Old 06-03-2012, 06:47 AM
Powerstroke Techie
I drove a truck with the eot in the filter cap. The reading was 30 to 40 degrees lower than the scanner was reading. If I was installing one I would be looking into a setup such as the edge cts or a scan-gauge.
Old 06-03-2012, 06:49 AM
I have a Spartan. It may seem odd but, I'm looking for a way to show FOMOCO I have oil temp issues without using the tuner. I don't figure they would appreciate it... LOL If I can spend a few hundred here to save thousands on oil cooler replacement I figure I'm money ahead...
Old 06-03-2012, 06:51 AM
That's interesting. Did you ever find a reason for the temp differences?
