Front and rear diffs and transfer case???
Well I hit 100k today and would like to change the front and rear diffs and the transfer case. Could anyone tell me what fluids to use and how much I will need. I have the 3.73 limited slip. I plan on getting royal purple with the friction modifier already in it. I just need to know weights and quantities. Thanks.
![]() I'd also lIke to know |
80w90 front, 75w140 rear and Mercon V in the transfercase.
thanks, do you know how much of each?
anyone???????
For the front diff you will need 5.8 pints (2.8L) of SAE 80W-90 Premium Rear Axle Lubricant
For the rear diff you will need 6.9 pints (3.3L) of SAW 75W-140 Synthetic Rear Axle Lubricant For the transfer case you will need 2 Quarts of Motorcraft Transfer Case Fluid (XL-12) |
Fluid change
I changed all the running gear (including trans) to Amsoil @ 5000, miles. Before I sold it, @ 200,000 miles, my 05 F250, 4x4, 6.0, auto, 3:73's, pulled a 40' toy hauler 80% of the time. No problems with any of the running gear.
Well this is what I ended up doing today...
oil change (motorcraft 15W40)√ fuel filters (Racor)√ transfer case (Mobil 1 ATF)√ rear diff (Valvoline Synth for limited slips)√ rotate tires √ I'm friggin beat. I decided against doing the front because I don't think it needs it and it isn't recommended until 150k. I don't use 4WD much anyway. |
