Puking?? - Ford Powerstroke Diesel Forum
Old 05-30-2012, 09:24 AM
Puking??
Just pulled over on the highway after running 300 miles popped tge hood and coolant it right at the top of the degas bottle and has puked out a bit. All temps are normal and I checked coolant 2 days ago it was at the cold fill line when cold. I was not towing and running steady 65 70 mph. Is a trip to the dealer in my future? I'm only running kem 175
Old 05-30-2012, 09:36 AM
Might be as simple as a bad cap. Many people here switch to a Stant cap after the stock one fails.
Old 05-30-2012, 09:39 AM
Bought a new cap 2 months ago it's been fine till now
Old 05-30-2012, 09:50 AM
Almostdunfukinwidit
The stant caps suck worse than the OEM ones
Old 05-30-2012, 05:38 PM
Can ford test my cap for psi??
Old 05-30-2012, 05:50 PM
They're cheap so just buy one instead of paying someone to pressure check it.
Old 05-30-2012, 05:53 PM
True I just did buy this one worried it might be faulty either way I just ordered ptp egr delete and hoping that fixes the problem. It only puked once today I kept checking drove another 200 miles it stayed lower now that it's cooled off its way below cold fill line
Old 05-30-2012, 06:20 PM
Can you support this statement please? I have switched to Stant due to the larger spring. I'm not disagreeing or arguing with you. Just want to know what you are basing this off of. Thanks!
Old 06-01-2012, 04:52 PM
Opinions are like a$$holes...
Old 06-01-2012, 06:03 PM
i did a egr delete awhile back and put a new cab on and since then i have been puking im kinda pissed i guess ill order a stant cap but were do i get it?
