diesel fuel additives - Ford Powerstroke Diesel Forum
Old 05-29-2012, 03:31 PM
I'm useing motorcraft cetane booster & lubricant, I'm looking for input on, howes meaner power cleaner, lucas, standyne, etc. Anyone heard of storeys fuel in cle elumn wa, they add additives from a on site tank. Popular place with truckers, spoke with a trucker filling up there, hes adding howes meaner cleaner. Great cash only prices they move a lot of fuel. They have conoco diesel fuel.
Old 05-29-2012, 05:45 PM
Fuel additives
Old 05-29-2012, 08:26 PM
I run grey bottle power service diesel Kleen and Lucas mixed. Sea foam once every other month.
Old 05-30-2012, 03:29 AM
This PDF is the sexy version of what Term3 provided; this study is phenomenal and extremely comprehensive:
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
Was using Ford Diesel Fuel Treatment, ordered the Opti-Lube XPD after reading that...
Bottom line is you need to do something, ULSD fuel's lubricity is horrible!
Old 05-30-2012, 05:23 AM
Do you put the seafoam in the tank or in the fuel filter housing?
Old 05-30-2012, 12:48 PM
So if I'm running B5 from the card lock then it should be even better!
Old 05-30-2012, 06:25 PM
Seafoam directly into tank. 90% of the time i mix 80% seafoam and 20% lucas fuel additive.
Seafoam has been around forever. I hate when people say it's not good for our trucks. It's what every major marine or CAT uses when filters or injectors get clogged. My diesel mechanic has over 600,000 on his 7.3 and has run seafoam every fillup. Mark my word--he has NEVER replaced an injector.
Old 05-31-2012, 04:21 PM
HUGE fan of Seafoam; excellent product!
Old 05-31-2012, 04:56 PM
Are you using a full can every fill up?
Old 05-31-2012, 07:23 PM
I use a full can about once a month. Shh is expensive!!
