Broken zerk on driver's side axle u joint - Ford Powerstroke Diesel Forum
Old 05-24-2012, 10:46 AM
Question Broken zerk on driver's side axle u joint
My 2010 F350 6.4 cc/sb 4x4 has a broken zerk on the driver's side front axle u joint. Can I replace just the zerk? If not, what u joint do I need to order? On fordparts.com, multiple u joints are listed but am not sure which is the correct one?
Additionally, if I do have to replace the u joint, should I be replacing anything else while I'm at it? I am at 70k miles.
Thanks for the help.
Old 05-24-2012, 10:56 AM
If you can get the broken one out go ahead and put new one in. If not, I personally would just leave it til its time for new u joints...
Old 05-24-2012, 12:39 PM
This is the u joint you would need.
Spicer 5-806X U Joint
Old 05-24-2012, 01:39 PM
Can anyone tell me or post a pic of where that fitting is?
Nevermind...found them. But also found a small oil leak from under the engine. Sucks!
