Edge Juice with Attitude programmer - 2008-2010 Ford 6.4L - Ford Powerstroke Diesel Forum
Old 05-22-2012, 08:53 PM
I found this on Cl & was wondering if anyone uses them & what is the learning curve. I do want to improve my mileage with the bigger tires (35").
"For sale is a Edge Juice w/ Attitude programmer for a Ford Super Duty 6.4L. It is in like new condition with the gauge pod to mount to the dash. This programmer is the only one that will allow "shift on the fly" with gauges to monitor. With this programmer I improved my mileage from 13mpg to 19mpg on a 2008 F350 with 37" tires. Everything works perfect and you can hook it up to verify.
KEY FEATURES
• Up to 70 HP and 150 ft. lbs. of torque
• Easy to install
• Choose from five different power levels and display a host of vehicle parameters
• Internet updatable
• Adjustable color screen
• Turbo Timer
• Retrieve and clear DTCs
• Tire size adjustment"
Old 05-22-2012, 10:22 PM
Better off with an H&S that will allow you to shift on the fly and also if you ever need to tune the tranny there is something else you can do but I can't seem to remember
Old 05-23-2012, 05:07 AM
Not everyone need to drop all that cash on a h&s. Don't get me wrong I like hs better but it his is dpf on tune and only 70hp extra I ran the same one before I got custom tunes geo
Kem. When I had my edge with 37 inch tires it did improve my mileage and the truck actually regen quite a bit less. If you are planning on doing the dpf delete in the future then you may as well go with the h&s or if money is not an issue get the h&s
