Need Help..
I just had new Heads, Head gaskets, Studs put on my 2008 6.4 with 130k I picked it up from the shop and I noticed a ticking sound thought maybe an exhaust leak. But also when I step on it I notice a hummmmmm coming from the turbo at about 2500 rpm. any ideas???
The humming was due to a exhaust leak but the ticking in was told was the high pressure fuel pump. Does that sound right or not?
Possible but I would have it checked out that damn pump isn't cheap don't want to risk burning it up. Where was exhaust leak ? On the manifold or turbo?
Turbo I do believe. I did not do the work myself. I trusted some dumb *** to do the work for me. I also read it might be from water getting that far in.
I will try and post video so I can get some better info.
what is this sound? |
Sounds like valves almost. I don't know its hard to tell on a video. Check your manifold bolts tho. Could be an exhaust leak
would the vavles not have been set on brand new heads from ford. the are both brand new.
They should have been, but I always check them again to ensure that they are correct. Sounds like valves to me as well.
I agree with you, always double check.
