biodiesel question
What do you guys think of using biodiesel. The main reason i am considering it is because it has higher cetane and higher lubricity. If so what percentage would be good to use? Do you think it will cause me any problems. Thanks for any advice. Here is the website for the company i would use.
Welcome to the Frontpage |
I have been using Texaco with 5% biodiesel (highest % recommended for the 6.4.) I find that it makes my truck run better with less injector noise. I have run Diesel Kleen in every tank.
I have read that there are potential concerns with biodiesel knocking debris loose in the fuel system and causing issues. I am not sure if this is with higher % biodiesel or just in poorly maintained fuel systems. I would be interested to hear from some other members and their first hand experience. |
How could i find out if the diesel i use is a certain percentage of biodiesel? Also are you deleted? I was thinking of running 20%. Would that be too much?
The Texaco and Exxon I go to say "Not to exceed 5% Biodiesel" on the pump. I am deleted running H&S tunes. I get quite a bit of injector noise running Shell or Exxon diesel when my truck is cold. I noticed a difference with the Biodiesel. I am a little nervous about running more than 5%, but I bet there are some guys on here that have tried.
From what i am gathering from research i think i will stay away from biodiesel. Thanks
From the owner's manual -
Diesel fuel containing no more than 5% biodiesel may be used. To help achieve acceptable engine performance and durability, it is important to only use biodiesel of good quality in your diesel engine. At a minimum, the biodiesel should comply with ASTM D6751 or an equivalent specification. Use of biodiesel in concentrations greater than 5% may cause damage to your vehicles fuel system components such as fuel tank, fuel lines, fuel pump, fuel sender and fuel injectors. Concentrations greater than 5% can also cause fuel filter restrictions that may result in a lack of power and or fuel pump and fuel injector failure. Look for a label on the fuel pump to confirm the amount of biodiesel contained in a diesel fuel. Biodiesel content is often indicated with the letter “B” followed by the percent of biodiesel in the fuel. For example, B5 indicates a fuel containing 5% biodiesel. Ask the service station attendant to confirm the biodiesel content of a diesel fuel if you do not see a label on the fuel pump. Biodiesel should not be stored in the fuel tank for more than three months. If your vehicle will be parked or stored for more than three months, then your vehicle should be drained and filled with a diesel fuel not containing biodiesel. During cold weather, if you have problems operating on biodiesel, you may need to use a diesel fuel with lower biodiesel content, try another brand, or discontinue the use of biodiesel. Biodiesel use may affect the recommended oil change intervals. Refer to the Special Operating Conditions section in the schedule maintenance guide for more information about oil change intervals and other maintenance when operating on biodiesel. Biodiesel fuel is a product that has been converted from renewable fuel sources, including vegetable oil, animal fat and cooking oil. Raw or refined vegetable oil, animal fat, cooking oil or recycled greases should not be used. There you have it. |
