Drivers side A/C problem - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-04-2012, 06:52 PM Thread Starter
I'm going to make this short and simple. My drivers side A/C blows hot air all the time while the passenger side works just fine. It just started and I haven't tried anything yet. Looking for ideas of where to start to find the problem. Oh ya, and I live in central Texas and its starting to get HOT around here! Thanks!
num12 is offline
post #2 of 11 Old 05-05-2012, 12:23 AM
You have dual automatic temperature control? The motor for the blend door on the drivers side has quit working.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 11 Old 05-05-2012, 10:38 AM Thread Starter
Yes it is dual temp control. Thanks for the info I'll check it out.
num12 is offline
post #4 of 11 Old 05-05-2012, 10:51 AM
Clayton1985's Avatar
And the driver side requires removal of dash to R&R.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #5 of 11 Old 05-05-2012, 08:03 PM
Pretty sure I have changed them without pulling the dash...its a squeeze for sure tho.
post #6 of 11 Old 05-06-2012, 05:28 PM
wilsonw2's Avatar
Quoted: 18 Post(s)
Recently took mine in for the same thing. I thought it was just the passenger side blender door...nope. It was both. Fixed under warranty. Dash out job. My ford mechanic also happens to be my buddy. He said they re engineered the doors. If u have not already he then upgraded under warranty.
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #7 of 11 Old 05-06-2012, 07:21 PM
Do you have part #'s handy?
1999 Corvette Cpe
post #8 of 11 Old 05-07-2012, 04:34 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
clayton--I will check my service receipt after work today for ya brother. Yours doin the same thing?
*NEW:
NL Fab:
---Stage 1 Intake
---------CCV Mod
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
wilsonw2 is offline
post #9 of 11 Old 05-07-2012, 05:39 AM
reighnman's Avatar
$25 part, $600 in labor from a dealer. It's the blend door motor/actuator and is a common point of failure for the dual climate zones. The passenger motor can be replaced without removal of the dash but not the driver side.
I've had my drivers side stuck on cold for the past year (winter sucked), and one of these weekends coming up I'm going to do a dash removal and document the steps.
I do recommend replacing all the blend door motors when the dash is off so you don't have to do it again anytime soon.
Black 2008 F250 Lariat 4x4 6.4L CC Job3, DPF/DOC Delete, H&S mini maxx, S&B Intake, vista-pro radiator
Black 2010 Mitsubishi Evolution, UR, AMS
reighnman is offline
post #10 of 11 Old 05-07-2012, 06:45 AM
Thanks bud! Yeah its been doing it pretty much since I bought the truck, and just realized the pass side only blows cold when set at coldest temp.
I figure Ill buy the parts and tackle it when im ready
1999 Corvette Cpe
