aluminum high in oil sample
My oil analysis also said I had high aluminum numbers in my oil. I also had a small amount of coolant in the oil (0.08%) Turned out the front cover was being cavitated and the coolant was slowly leaking into the oil. I know you don't have coolant in your oil but the front cover on the water pump is made out of aluminum .... just something to keep in mind, especially if you start loosing coolant or seeing it in your oil. Good luck.
Pops-what kind of oil are you using?
I am using motorcraft 15w-40
My last Blackstone seems to be exactly the same as Hunters. I talked to the dealership and they said they should be able to do it under warranty, but would need my truck for a few days to diagnose that it is because of the old front cover design. I'll be dropping it off on Monday. I'll keep y'all updated.
