Hey guys a little input here if u can
I didnt get a wrench light or anything but I got a dtc on the Mini. Says "P008E Fuel cooler pumpp High Circuit"
A little while ago the truck had to go to ford for the weird hum noise, ended up being the new fuel cooler wasnt bled properly. So they bled it and added coolant. Problem is I am now 2000 miles away from that dealer so cant really ask em to fix it. I am JUST out of warranty now too d**n it. Question is. I can get a replacement cooler pump from Ford Parts | OEM Ford Parts | Genuine OEM Ford Parts (which i ordered my harley HL from and were great) I can get the pump for 97 bucks. Where is the pump located? And is the little resevoir by the turbo (the black plastic one) the tank for the fuel cooler? What goes in there, just coolant? and if so how much? Thanks guys! |
BUmp... ANyone??????
not sure where the pump is but your right thats the reservoir and it uses 50/50 ford gold coolant. there in a allan key bolt on the turbo accuator and thats what you open to bleed it as you poor in new coolant....i believe thats the correct way...hopefully someone will let me know if I'm wrong. I went to bleed mine and add more coolant and i can't get the allan screw open who ever put it on last really snugged it up I've broken two allen wrenches trying to get it off now
Thanks. Yeah i am trying to find out where the pump is. I looked at the microfiche and it looks like it should be on the driver side by the rad somewhere.. But I cant seem to locate it. And wondering if anyone else has experienced this...
Any techs on here know where the pump is located and any experience with that DTC? I am wondering if its shot? or loose connection....
The pump is located on the lower driver side of the radiator shroud. The easiest way to get to it is to remove the plastic inner fender (driver side of course) and you'll see it there.
Thanks! Thats what I was thinking.. Have u heard of that code before? Is the pump smoked do u think? Safe bet to probably just replace I am assuming so I dont fry the HPFP....
I've never heard of the code before. The only reason I know where the pump is located is because I had that inner fender out doing an EGR cooler delete and saw it there.
Yeah its a new one on me.... Just weird that the truck didnt pick it up and set a wrench light
