Pulley noise - Ford Powerstroke Diesel Forum
Old 04-18-2012, 03:47 PM
Send a message via AIM to BLKF250
Pulley noise
Was wondering the best way to test a pulley to make sure it's the right one to replace. Iam getting a squeak noise nothing crazy but enough to piss me off lol I believe it's the idler pulley the bearing inside went bad. Only does it when it's cold as it warms up it disappears try putting grease on it didnt do much. Try spraying WD40 on it to see if it does anything to help me determine the right pulley seems to help because the noise got louder then quiet down a little but I was just seeing if there was a way to test it. Thanks guys
Old 04-18-2012, 04:21 PM
Ya its your idler pulley its the first one just go pick one up at local parts dealership and install it. DO IT YOURSELF unless you have warranty still
Old 04-18-2012, 06:54 PM
Have u had this problem yourself? When you say first idler pulley you refer to the one next to the alternator above the tensioner pulley correct? Iam gonna get one from ford it's only $40 probably going to replace it the same time I do my EGR delete.
Old 04-18-2012, 08:38 PM
Yup i have it is acutally comin in these trucks for them to go out and ya i think that one is it
Old 04-18-2012, 08:43 PM
very common problem like benstroke said its definitely the idler pulley
Old 04-19-2012, 02:48 PM
Sweet thanks guys I am going to put my order in and get me one of those to take care of this
