water fuel separator problems - Ford Powerstroke Diesel Forum
Old 04-16-2012, 07:50 AM
I drain my water fuel separator at least once a month. I always drain it into a water bottle and mostly fills up with fuel and the odd time a drop or two of water mixed in there. Today I went to drain it again and nothing came out at all. I stuck a pin up there and slowly it stated to drain mainly steady drops usually it pours out. I went to check it again a bit later and again absolutely nothing comes out. Its been below freezing all week out do you think that the maybe i got a bad batch of fuel with lots of water in it and now because of the temps its frozen in there? Can I take the cover for the lever off and clear out any debris or does that cover not work like that. Thanks in advance I want to get this taken care of asap. Also I change my fuel filters every 8000 miles
Old 04-16-2012, 08:20 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
It could just be gunk in the filter housing that is frozen. What does your fuel pressure look like? Is it still running about the same? I dont think the lever comes off. Best thing to do is pull the filter and scrape out any gunk you have in there and see what that does for you.
Old 04-16-2012, 09:52 AM
I have the edge race so I'm not able to monitor the fuel pressure but the truck is running fine id be more concerned if i didn't drain it on a regular basis but i last drained it about 3 weeks ago. Im working out on the rigs right now so i won't be able to look at it for the next week or so hopefully I don't damage anything by driving it
Old 04-16-2012, 09:55 AM
If you can, add some anti gel and see if that frees anything up. Im on the rigs myself right now, but its in the 40's here in North Dakota.
Old 04-16-2012, 10:05 AM
I wish it was 40 here we just got hit with spring snowstorm now it will melt and make the roads a mess again! Thanks for the help
Old 04-16-2012, 12:19 PM
UPDATE: I tried it again this afternoon after the temperature was above freezing for a while and it drained no problem and a very tiny bit of water the rest was clean diesel so it must have been frozen and there was a little blockage
Old 04-16-2012, 05:38 PM
sounds like good news.
