Normal Operating Temperatures - Ford Powerstroke Diesel Forum
Old 04-15-2012, 08:34 AM
I have and H&S tuner set on Hot and was wondering what your normal temperatures are for the oil and coolant. In winter mine would be right around 192-194. Yesterday it was warmer, somewhere in the 70's and they were around 197-199...seemed kind of high to me? Just would like to hear some others input.
Thanks
Old 04-15-2012, 08:47 AM
on normal hi-way driving my coolant is usually 192-194 and my oil sits at 196-198 They do get a little bit hotter sometimes going up hills and things like that i would say your temps are normal just keep an eye on the difference your oil should be anywhere from 2-6 higher then ect if it gets anywhere over 15 your oil cooler is shot. Hope this helps
Old 04-15-2012, 08:52 AM
alright thanks man!
Old 04-16-2012, 05:27 AM
My coolant temps are also in the 192-194 range. They get a little hote with the hotter weather or depending on the load. EOT is about 2-4 degrees higher than that.
