Return tuner to factory please...
Can someone give me a step by step to retune the truck to factory settings and add the Dpf so I can put my exhaust back on for warranty work and emissions and remove the tuner.
On a second note, my truck displayed "check brake system" during startup and then threw on the check engine/abs/battery light, any thoughts? Truck drives and stops just fine. |
if only we knew what tuner you are running
Mine did that the other day. It ended up being the batteries. And it say he is running H&S.
oh, I have sigs turned off because of the poster sized pictures some people have in their sigs
So did your truck say "check brake system"? Or just the battery light came on? |
It just said check brake system. I posted a thread in the problems section and everyone said check your batteries. After I installed the new ones I tested the old and one was no good. But since they were the original's I replaced both.
No one knows the steps to return the truck back to stock settings with the Dpf added?
go to install downlod, return to stock
Thanks, easy enough.
It would have been easier to just follow the steps on the tuner... Or go to the H&S website and follow the instructions. Yeah, those would have been easier... Faster too.
