08 programming thoughts, what do you think?
I've been thinking guys and I had a rant about thing before but I want your input on it......now when you reprogram a diesel, any diesel ,GM, Ford, Dodge, etc...you usually get more smoke, some times a lot more smoke right? I have noticed that a lot more guys are coming on here complaining about not enough power and programming options for the 6.4.....now I read in Diesel Power about the reprogramming of a 6.4 with Bully Dog and the editor said the truck went into regen a lot more, meaning that they DPF was getting clogged a lot more. Now I wouldn't know because I was smart enough (yeah right) to gut my DPF....here is my question what happens when the DPF goes bad because of the excess regens and its time for replacement? If the truck is reprogrammed the dealer isn't going to do it under warranty any way, so why not get rid of it all together .....just a thought for those who are looking to reprogram the new 6.4 and keep the DPF on.....
I don't know but that seems like a good question.
I seems like removing the DPF isn't worth the risk of loosing your warranty.
So would you agree that if you don't want to lose the warranty period, you shouldn't do a programmer at all regardless if they can see if you have reprogrammed the truck or not???
I wouldn't. When i was talking with the Ford guys from Texas that came up they confirmed that any type of reflash could be seen. Unless i had some extra cash laying around for when something goes wrong i know i wouldn't be touching anything.
program or don't
It's a matter of deciding how badly you think you need the warranty. Since there've been programmers and other neat add-ons to hop up the P'Stroke, we've been doing it, but we always wait until at least 10000 kms to make sure we're okay and that was learned by accident. I actually had a 2001 7.3L dually take off on a runaway - couldn't shut the engine down, tach pinned, until it even sucked out and burned off all the engine oil and melted her down. That was at about 1000 miles and I hadn't touched that one yet - good thing, so it was all warranted to the tune of a brand new $20K install, right off the line. All the same, my '08 dually's getting stripped of the the whole exhaust system once the more common programmers come with a full-bore regen delete. Without removing the delete cycle I wouldn't dare run an aftermarket exhaust just as I wouldn't dare run with the PDF still in place and no regen cycle - it'll plug off and that's it for the engine in short order. I still think this 6.4 is a helluva good engine, but I also think it was prematurely released. The aftermarket will fix it up, I'm sure. and as I mentioned in a different post, I refuse to believe there are fewer emissions from burning way more diesel fuel no matter what's on the exhaust system
Really it depends on a lot of things. I've never seen it stated by Ford that the DPF is limited to X amount of regens before requiring replacement. More frequent regens just mean worse fuel economy not necessarily sooner failure. As for the dealer knowing about a tune I've heard they can tell and I've heard techs tell me no they can't. If you have a dealer that doesn't care then it doesn't matter either way.
My personal feeling is I want the DPF gone from the truck however I won't touch it till I feel comfortable that there are no major issues. I've owned many vehicles and anything major (that isn't my fault) has shown itself in the first 20-30K miles...usually sooner. Barring any head stud/head gasket issues or other major failures by the time I hit the end of my base warranty I will more than likely remove my DPF and get a tuner. If a severe enough problem occurred after I did that I would put the DPF back on and return it to stock and deal with a dealership that is modification friendly. Otherwise it's on me anyways. Bill |
IF you are going to program the truck, remove the DPF -- if you aren't going to remove the DPG - its almost pointless to get a tuner IMO
What I meant was if you gut your DPF so you don't have to buy a new one thats around I think $1300 (correct me if I'm wrong). I think the DPF gets worn out over time instead of getting plugged. Here's the thing if you gut the DPF to save money but you'll end up loosing your warranty. Later on down the road gutting the DPF caused the turbo to overspin come apart and go into the engine destroying it your out a good amount of money probably $18000. It sounds like you are trying to save $1300 but you loose your warranty and then you run the risk of loosing $18000 on a non proven engine. I would program the 6.4 with the exhaust untouched and if something did go wrong I would set it back to stock and then take it to the dealer. The dealer I go to doesn't really care about my programmer as long as they see I'm not destroying the truck. Honestly I like warranty's because there cheap and easy to use.
