Constant regen after lift + tires - Ford Powerstroke Diesel Forum
Old 03-23-2012, 11:54 AM
Anyone experienced this? Installed the lift myself, ran fine for a day. Took it in yesterday to have pitman arm + tires mounted and installed and since I have pretty much been in regen since. MPG is reading 8.2. Its only a 4.5" lift and 35" tires. I was running ~15 MPG before this...should I expect my MPG to be cut in half like that??? I am guessing its so bad due to constant regen.
I know I need to delete the DPF but a tuner is not affordable for me quite yet...
Old 03-23-2012, 01:49 PM
Thats the only way i would go just bite the bullet and then you should gain mpg or atleast stay the same
Old 03-23-2012, 02:09 PM
I don't think it should have cut in half. If your in constant regen, then you got something wrong like maybe stuck injectors or something.
Old 03-23-2012, 02:23 PM
Something is not right it has nothing to do with the lift when I still had my dpf and did my 6inch lift on 37 I didn't knotice any difference on regen
Old 03-23-2012, 02:25 PM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
Have you been driving around letting the regen finnish or have you been shutting the truck off in the middle of a regen? If you turn the truck off before its finnished it will start back up again from the beginning when you start driving again.
Old 03-23-2012, 02:45 PM
Well I just made a 10 mile trip home and no regen. MPG made it back up to 10.5. It could have been a coincidence and the regen just never was able to finish but man what strange timing! Tomorrow I'll drive it down the highway a little and see how the regen is.
Is there a certain number of miles or any metric I can go by to make sure it is done with the regen?
Old 03-23-2012, 03:27 PM
I dont remember all that well, but I believe that the message on the dash will disappear when regen is done. If I remember correctly my regens used to take about 20-30 min when I still had my DPF (2 years ago)
Old 03-23-2012, 07:57 PM
Used to be that way, but anyone who has received a Ford flash in the last year knows that that message no longer stays on the screen as it did. Thesedays, it displays for about 2-3 seconds, then it disappears. Other then a 3rd party monitor, only other way to tell is by knowing how your truck sounds and runs or cycling through the msg center.
Sent from my EVO using AutoGuide app.
Old 03-23-2012, 08:00 PM
I go by sound now...but thats still annoying. I wish they just had a light on the panel that stayed on during regen.
Old 03-24-2012, 05:53 AM
Well thats good info to know. Im sure there is someone out there who could design a little LED that would come on when the regen is happening. In my head it wouldnt be that hard as long as you could find a wire that had juice only during regen.
