fuel additives
what if any additives are yall using? i've heard tell, that i should be using additives to help save my fuel system, I haven't checked the manual on this yet but plan on doing so, Ford just replaced my injector pump, so I really think i should look into this, I as told that especially on the 6.7, any thoughts on this..???
I have been running the ford cetane booster for the last 500 miles. It actually seemed to quiet it down a bit. I can be sitting in the drivers seat with the windows down with the engine running and carry on a normal conversation with someone standing outside the truck. Also, the kids working the drive through window at whataburger have stopped asking me to shut the truck off when placing an order. I have heard that the lubricosity is ok with the ford product, and i have had a good experience with it, but the best is supposed to be stanodyne for lubricosity. Hope this helps. Btw, i think the ford stuff is about $8.00 ant treats about 4 tanks worth.
I generally run the Rev X or Archoil fuel additives.
I run DieselKleen and also have the RBP Performance Additive. The RBP gives her a little extra punch.
Power service Diesel Kleen.
Isn't the ford stuff the same as standoyne?
That's what I have always heard.
-Aaron |
I've always used diesel kleen mainly because most people use it and it's super easy to get but has any one used Schaeffer Diesel Treat 2000? I came across it a while ago and havnt heard much about it other the on that lubricity additive thread it looks like it does a good job
I use Standyne or Power Service. Power service is easier to find at your local walmart.
i also use diesel kleen. I would like to try that archoil. Its expensive tho.
