oil change - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-19-2012, 03:23 PM Thread Starter
oil change
Doing my first oil change. What oil is recommended for a 08 6.4
FORDTRUCKLVR is offline
post #2 of 12 Old 03-19-2012, 04:03 PM
44magnum's Avatar
Quoted: 2 Post(s)
It says in your manual, 5w40 is what your looking for. Go synthetic if you can swing it.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #3 of 12 Old 03-19-2012, 05:53 PM
dieselfreek26's Avatar
Ran 15W40 Rotella for a year then switched to Rotella 5W40 synthetic
2008 CCSB F-350, Newton Level, Custom Harley lights, 6000k H&F, Spartan 300 LL, 4" Turbo back MBRP AD 6", S&B, Blocker Plates, CCV Mod, MBRP CAC, BMF Novakanes, Toyo MTs
dieselfreek26 is offline
post #4 of 12 Old 03-19-2012, 06:18 PM Thread Starter
What have you heard about Mobil Delo
post #5 of 12 Old 03-19-2012, 06:31 PM
leftea's Avatar
i go the simple route. every 5k miles, 3 jugs motorcraft 15w40 and motorcraft filter at walmart. i keep the receipts in the glove box just in case.
-0IIIII0-
leftea is offline
post #6 of 12 Old 03-19-2012, 09:51 PM
Ran Rotella-T6 5W40 for several years. No have just Rotella-T 15W40 and can't say I can tell any difference.
A Fumoto valve makes draining much easier. Once installed you can climb under the truck and place a gallon jug under, open the valve until the jug is full. Swap for the next and repeat until drained.
2008 F250 Lariat CC 4x4 white/gold
n4hhe is offline
post #7 of 12 Old 03-19-2012, 09:52 PM
Only 3 gallons? 12 quarts in a 15 quart system?
n4hhe is offline
post #8 of 12 Old 03-20-2012, 04:29 AM
strokin07's Avatar
Exactly what I was thinking.
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #9 of 12 Old 03-20-2012, 04:50 AM
Motorcraft jugs are 5 not 4 like all others, made for Ford !
DieselFord is offline
post #10 of 12 Old 03-20-2012, 05:50 AM
strokin07's Avatar
Ahah! Way to go Ford.
2008 F-250 KR
7" ICON
7" PMF blocks
22x14 Fuel Octane
37" Toyo M/T
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
