What's Normal? - Ford Powerstroke Diesel Forum
Old 03-17-2012, 12:43 PM
What's Normal?
Under no load and light to medium acceleration, what is considered normal turbo boost? I get about a 10 (first notch) on the meter. Just wondering if that's what it's supposed to be.
Old 03-17-2012, 02:55 PM
What do you show on a wide open throttle acceleration.
Old 03-17-2012, 03:07 PM
The most I've ever seen under light load (going up a hill or something) is 20. To my knowledge I've never had it at WOT. I'm not having boost issues (at least I guess I'm not), I'm just curious as to what is normal under those conditions.
Old 03-17-2012, 03:13 PM
Not sure they wil hit 35 stock. If all you will hit is 20 psi might have a boost leak.
Old 03-17-2012, 03:23 PM
Okay, but again, I've never really had it under any load at all. I don't tow or haul anything...not even a boat. I just climb a hill from time to time. That being said, I just assume it's never been in a position to need a lot of boost. Am I wrong?
Old 03-17-2012, 03:26 PM
Maybe completely normal.
Old 03-17-2012, 03:31 PM
Yes, it may be, that's why I asked. This is the first diesel I've had with any kind of boost gauge so I don't know what normal is.
Old 03-17-2012, 03:33 PM
Under normal acc it should def make atleast 20/25psi.
Old 03-17-2012, 03:40 PM
Completely stock and non-tuned? Again, it does hit 20 going up even the smallest hill...even the freeway on-ramp.
Old 03-17-2012, 03:44 PM
Run it wot and it should hit atleast 32psi if not you might hVe a egr prob.
