squeal under acceleration!!!Help - Ford Powerstroke Diesel Forum
Old 03-01-2012, 03:11 PM
I have a 08 F350 6.4 and just did the tuner dpf delete and dual flo pro exhaust and now i have a VERY high pitched squeal coming from somewhere!!! It only does it when I accelerate and around 2500 rpm.....when it starts you let off a bit and it goes away...what could that be?
Old 03-01-2012, 07:02 PM
Feedback Score: 3 reviews
Mine does the same thing sometimes, almost sounds like one of the turbos, like maybe the VGT actuating? I think i'm going to rebuild my turbos soon if they're still in decent shape.
Old 03-01-2012, 07:18 PM
but it is only at 2000ish rpm....give it the juice and is stops.....let off and it stops....been told it might be a crack in my flex pipe frm the turbo to the exhaust
Old 03-01-2012, 07:28 PM
Mine used to make that noise at the same rpms(2300-2450) before I Deleted. Since then, I haven't heard it once.
Old 03-01-2012, 07:30 PM
what did you delete?
Old 03-01-2012, 07:42 PM
Right..... since I deleted the dpf. I always thought it had something to do with regen and towing
Old 03-01-2012, 07:43 PM
I have deleted the dpf and put a aftermarket exhaust on it.....sorry im new at the 6.4
Old 03-01-2012, 09:02 PM
COuld be the pipe, OR it also very would could be the Degas bottle cap... I know my buddies was doing that and I told him that they are all crap caps and ford has a new design out. He went and bought one and it has a much stiffer spring and it keeps the needed pressure in the system, and voila no more noise.
You can buy a Stant one for 5 bucks at Advance Auto or its 13.99 from Ford.
Try that, either way u should change the cap anyways.
Old 03-02-2012, 02:55 AM
Check for soot @ the flex joint on one of your up pipes! common problem, sound like an old mans hearing aid going off!
Old 03-02-2012, 03:34 AM
number two this morn lol sounds like up pipes to me
