Jake brake - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-17-2007, 10:29 PM Thread Starter
gweaver202's Avatar
Jake brake
If Ford is so adamant about NOT having an exhaust brake on the F-250 & 350, why do they offer an exhaust brake on the 550. Seems that an exhaust brake on the 250 & 350 would be a safety issue when towing heavy trailers, etc.
gweaver202 is offline
post #2 of 6 Old 09-17-2007, 11:33 PM
The Fat Mod
Logan's Avatar
I guess they look at it as if you are going to be pulling that heavy, you need a heavier truck...ie 550. Also, with the torque shift and the tow haul mode, it does pretty good.
Logan is offline
post #3 of 6 Old 09-18-2007, 09:55 PM
StarDriver's Avatar
Also, the 550s are in a different class and have different engines and also fall into different emissions classes.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #4 of 6 Old 09-18-2007, 10:15 PM Thread Starter
gweaver202's Avatar
Your right, I went back to this web aite and checked! Cumming and Cat engines. Something I discovered that could scare you is that in the discussion Ford make mention of the fact that some engine service might require the cab to be removed.
https://www.fleet.ford.com/truckbbas...ingsession.pdf
Thanks for answering, I suspect I will still order my dream truck -- even without the cab. LOL
post #5 of 6 Old 09-19-2007, 05:22 PM
DavidPhillips's Avatar
Check and see what a jake brake is. It's built into the engine only. The exhaust valves close.
You can get an exhaust brake but unless the TCM knows about it you could still be just coasting if the TC unlocks unless you have a standard.
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #6 of 6 Old 09-19-2007, 05:33 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
I believe its the 650's that start with the different engine options. Cause then you are getting a medium duty chassis. The 550 is still the regular ford body. The 650 and up has the tilt forward big rig style hood and bigger axles,etc....
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
