REGEN mode ? - Ford Powerstroke Diesel Forum
Old 09-16-2007, 08:43 PM
REGEN mode ?
i know what regen is but when does it do it? ive herd some people saying it does it at random, so how do you know when its doing it?
Old 09-16-2007, 08:46 PM
it does it when ever the compooper sences that your particulate filter has to much soot in it (sensors in the exhaust pipe) theirs some deeper tech into it than that but thats about the easiest way to explain it usualy the idle goes up when it goes into regen unless its in gear.
Old 09-16-2007, 08:50 PM
got ya cool, i figured when it idled up that it was but i wasent sure.
Old 09-17-2007, 07:42 AM
does regen become a hinderance or problem does it stop u ever from using your truck as u wanted to when u wanted? like iwll it try and regen while towing for example?
Old 09-17-2007, 03:53 PM
its not suposed to effect the drivability at all all it does is increase the egt's to burn off the soot trapped in the filter
Old 09-17-2007, 03:58 PM
BIG TRUCK, SMALL DRIVER
It doesn't effect anything while driving. It stops and waits for the truck to go back to idle.
Old 09-18-2007, 08:20 AM
Maybe it isn't suppose to affect anything while driving but it does. There is a distinct power loss while it is in regen mode. When the truck is in normal mode the truck has very good throttle response at speed...while in regen mode it takes more to get the truck moving. I can see it being a possible issue while towing.
Bill
Old 09-18-2007, 08:25 AM
Let's Run'em
Bill
.....yeah there is a distinct power loss along with a different exhaust sound, its deeper
Old 09-18-2007, 01:40 PM
Maybe our gearing hides it a bit. The only time I can tell is when I pull to a stop.
Old 09-18-2007, 01:44 PM
Let's Run'em
Yeah because when my truck was doing it, it almost felt like the parking brake was on...
