does anyone know if i can run a - Ford Powerstroke Diesel Forum
Old 02-07-2012, 08:46 AM
17" wheel on my 08 250?? I have factory 20's but have never been a fan of 20" wheels for some reason... I don't have TPMS on mine either. If anyone knows it would be much appreciated! thanks
Old 02-07-2012, 09:26 AM
Yup you can run 17" rims, but that's as small as you can go. Anything smaller wont clear the calipers.
Old 02-07-2012, 09:29 AM
sweet thanks man!!!!!!!
Old 02-07-2012, 09:53 AM
also does anyone know if a 17x9 wheel with a 0 offset will work with 315/70/17 tires? I plan to run a 4" or 6" lift soon.
Old 02-07-2012, 11:17 AM
bump....................... is a zero offset ok?
Old 02-07-2012, 11:23 AM
That's a perfect off set for your truck. Tires will stick out an inch or so.
Sent from my DROID2 using AutoGuide.com App
Old 02-07-2012, 10:08 PM
thanks man!!! i want 18's... but there aren't as many tire choices in 18 unless i want a wider tire which i don't...
Old 02-08-2012, 04:36 AM
I run 17x9's with 0 offset and I clear 37's with a 4.5" lift.
Old 02-08-2012, 04:59 AM
Send a message via Yahoo to skipnay
On my 2008 F250/F350 I have 18'' wheels. They have plenty of options for 17'' wheels and 1 16'' steel wheel that was from factory. I wouldn't go any smaller then 17'' though.
Old 02-08-2012, 07:25 PM
My dad has a set of 16" wheels from his '02 F-350 he wants to give me. I'm not sure if these would fit my '08 F-350, what do you guys think? I currently have 18" steel wheels from the factory that I'm running on.
