airdog and filter ???
How often are you guys changing the engine mounted fuel filter after you install the airdog? Does it still need to be changed every 10,000? Also how oftern are you changing the airdog filter? Thanks
I ask the same question a while back and no one gave me a exact answer. But you did post in that thread and you said you were going to replace the filters 10k miles anyways.
I go by pressure. In two years I've replaced it once.
Which pressure do you monitor? Do you have a minimaxx?
Ya im kinda thinking i will change it every 10,000 still. Better safe than sorry. I just thought id see what everyone had to say. How often do you change your airdog filter?
Fuel pressure entering the heads. No to the Minimaxx, Dakota Digital gauges
I just got it installed about a month ago so I haven't been 10k miles. I've only been about 3500 or so miles since the installed. So I still have some time.
The paperwork that came with my air dog system says yearly. I now change my fuel filter in the fuel bowl every 15,000 or every third oil change.
If you have the two micron filter for the AD2 you don't even need the filter in the engine mounted fuel bowl as it is also two micron.
