Dark water in separator
The last two ones that I have checked my water separator the water coming out has been pretty dark. Almost looks like dr pepper or something like that? Up until now the water has always been clear. Has anyone ever seen this and is this something I should even be worried about?
Thanks! Sent from my Autoguide iPhone app |
I'd be worried about ANY water!!!!
I've never had any water when draining the separator |
no water in my separator 52000 mi, I've put 7000 mi on my 6.4, drained 3- times, clean light green fuel.
Dr.Pepper! I always get the yellow/green fuel color when I drain, kind of like Mountain Dew
![]() Edit- Do you change your fuel filters? What does the filter look like? |
Yes I change the fuel filters every 10000....I have always had small amounts of water when I check my separator, and I check it about once a week at the longest and sometimes more. *When I change my filters they always look what. Would expect to be normal. *A little dirty but actually not much different than a wet new filter. And no, I'm not wetting the new filters before I install them*
![]() I have driven big trucks for years and it is common to find water in diesel. I would be surprised that guys are getting no water whatsoever in their diesel fuel. But hey, if not that's great. I wish I could say the same for any of my diesel trucks. I took a picture of the water and will post it when I can get it to the right size. |
If you live in a region that regularly has water in the fuel, I would highly recommend an aftermarket water separator and filtration unit. A common rail fuel system won't last long under those conditions
I fill up at half tank when practical. Shell or Chevron when possible, seems to run best on this fuel. Using motorcraft cetane booster as reccomemded by dealer.
Here is a picture of what the water looked like.
http://m1259.photobucket.com/albumvi...6.jpg.html?o=0 Sent from my Autoguide iPhone app |
As far as having crud in the HFCM I am thinking that is probably the most likely scenario.
I will change the fuel filter and check it out before I hit the road again. I drive about 500-800 miles a week Thanks for the input guys! Sent from my Autoguide iPhone app |
