Cleaned HFCM filter and she want start - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-27-2012, 11:34 AM Thread Starter
Clean HFCM , replace filter , primed 6 times started right up. Ran her for 5 minutes. Then replaced engine (Top) fuel filter and primed 6 times and she wont fire ??
2008 F-350 Looongbed CC 4x4 Mini Maxx S@B C.A.I. Delete Pipe , Custom 2 1/2" leveling kit
UPTHECREEK is offline
post #2 of 10 Old 01-27-2012, 01:36 PM Thread Starter
Anybody
post #3 of 10 Old 01-27-2012, 02:13 PM
CT9AIX's Avatar
Not sure boss. I've never ran into any issues with starting the truck after a fuel filter change when doing the prime procedure? May sound dumb, but drain some fuel out, take the cover back off the lower filter housing like your chaging it again, and go through the same steps as if you were changing the filter again with the priming ect. Other than that dont really know since the truck already ran once after you cleaned and reinstalled the HFCM.
CT9AIX is offline
post #4 of 10 Old 01-27-2012, 05:11 PM Thread Starter
Thanks for reply , I'm now charging my batteries back up I'll try going back thru it tomorrow ....
post #5 of 10 Old 01-28-2012, 06:38 AM
XPLOSIV's Avatar
Are any codes showing up?
Sent from my ADR6300 using Tapatalk
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #6 of 10 Old 01-28-2012, 08:55 AM Thread Starter
Dont see any , on dash ?
post #7 of 10 Old 01-28-2012, 12:40 PM
XPLOSIV's Avatar
Can you check for DTC's on your Mini Max. Not sure, as I have a Spartan. How bad did the filters look?
08 F450 CCLB 4.30's
XPLOSIV is offline
post #8 of 10 Old 01-28-2012, 12:47 PM
lhsnbsaoa's Avatar
Garage
The mini maxx will let you scan. I've done it.
Sent from the mower shop
1996 F350 Dually Centurion
Previous trucks: 2003 F-250, 1997 F-350 CCLB, 2000 F-350 CCLB, 2008 F-250 CCLB
lhsnbsaoa is offline
post #9 of 10 Old 01-28-2012, 04:02 PM Thread Starter
Finally got it started after 2 days , Not sure what I did , But I took the HFCM back apart and pulled its filter out and rechecked the manifold gasket and then primed the streator valve till I got solid fuel , primed some more and finally she fired. Thanks for all the advice , This one about whooped me .
post #10 of 10 Old 01-28-2012, 06:36 PM
2x6 bulldog's Avatar
The best way to prime the fuel system after fuel filter changes is to turn the key from off position to on position waiting 30 seconds on then off. I usually do this 10 or 12 times. Six is enough sometimes but it doesn't hurt anything to do it a dozen or more times to be sure it starts and runs the first time. I never touch the schrader valve when I prime the system. If it is quiet and you leave the driver door open you can hear the electric fuel pump run then quit on each key cycle.
2008 F450 Lariet CC 4x4 dually 6.4 diesel
2x6 bulldog is offline
