Over Boost - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-26-2012, 08:56 PM Thread Starter
lancinfish's Avatar
Send a message via AIM to lancinfish
Over Boost
I have searched all the forums and I am stumped. I am having a problem with the truck going into limp mode because of Over Boost. It happens any time I tow something with my SCT Livewire on any setting other than stock. Even on the tow mode, on a high bridge towing my 17' Aquasport it did it. Thats just crap because that boat does not weigh anything. I could tow that boat with a Prius, but my truck over boosts when towing it in Tow mode.
How should I address this? I would like to get it fixed. I like the extra power that the tuner give me.
2008 F-350 LWB CC 4x4 Lariat
Leveled
Diamon Eye downpipe back exhaust & Hushpower muffler
SCT Livewire
AFE Intake
Line-X
Gear Double Pump 20" Rims
Tokyo Open Country A/T II 35x12.50R20
"Peace is that brief glorious moment in history when everybody stands around reloading".
Thomas Jefferson
lancinfish is offline
post #2 of 9 Old 01-26-2012, 08:58 PM
2003kingranch's Avatar
do you have custom tunes?
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 9 Old 01-26-2012, 09:28 PM Thread Starter
lancinfish's Avatar
No, Just the stock ones on the SCT. Never purchased them as i wanted to see how this thing would do before I spent more money. So far, I am running the Stock tune w/o the DPF so that it does not go into regen. Seems to be ok so far, but I have not had a large load to tow in a few weeks to test it out in the "Stock" setting.
Leveled
SCT Livewire
AFE Intake
Line-X
Thomas Jefferson
post #4 of 9 Old 01-27-2012, 12:21 PM
Not sure about the SCT but I was running an Edge programmer and mine did the same thing. Had to take it into Ford and get the most up to date "Flash" and now everything is fine. Apparently the previous "Flash" that was an upgrade was the culprit. Now I have the H&S MiniMax with KEM tunes/DPF/CAT Delete and no problems. Hope this helps.
timothytyson32 is offline
post #5 of 9 Old 01-27-2012, 09:31 PM
I'd invest in custom tunes. It's night and day difference. canned tunes just run like crap. That's just how it is
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #6 of 9 Old 01-28-2012, 04:42 PM
deamsphelps's Avatar
Maybe canned tunes from the wrong company. My canned H&S tunes work fine. Good luck.
deamsphelps is offline
post #7 of 9 Old 01-29-2012, 06:28 AM
i know h&s & spartan canned tunes are great. my experience with sct canned tunes (on my 6.0) is that they suck. at least on my truck they do. sct canned tow tune (55hp) runs hotter and makes as much boost as my 150+ hp slr race tune that runs cooler.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #8 of 9 Old 01-29-2012, 07:47 PM
integrityinc's Avatar
Mine did that when my dealer flashed my truck...(w/out permission I might add.. Unplugged my tuner that was not set back to stock, and flashed me...GRRRRRRRRR!!)
I had all sorts of problems after that. I actually started a thread re: that that if you like you can check out on my profile.
Sum it up to say H&S solved my problem and now I have an Edge CTS sitting on the shelf...
integrityinc is offline
post #9 of 9 Old 01-31-2012, 07:53 AM
I have been having the same problem. My truck is stock and when towing my 7x16 enclosed trailer loaded or empty my truck overboosts and goes into limp mode. usually on a long pull in overdrive with or without tow mode switched on or not, no downshift just added boost it will just keep boosting and gets up to as high as 40lbs of boost and then goes into limp mode. Had it back to dealer after it did it last week and they reflashed the computer(reflashed 6 mnths ago) now this weekend it still boosts to 40lbs but it hasn't gone into limp mode.
Since the reflash my milage went down and now i can hear the turbo wistle, very faintly but i can now hear it when I couldnt before they reflashed the comuter.
is 40 Lbs to much boost? should I be concerned or leave it alone unless it goes limp again??
Seacoast Energy is offline
