pmf drag link - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-26-2012, 11:40 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
pmf drag link
I am almost to hit 100,000 miles and i am going to freshen up the front end a bit. I am going to do ball joints, u joints, axel seals, track bar ball joint and track bar bushing. I am thinking about doing pmf's drag link. I have a stock height truck and he said he can make me one for stock height? Has anyone used his drag link? Is it worth upgrading? Thanks for any info.
HD Single Piece Draglink - Precision Metal Fab
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #2 of 19 Old 01-26-2012, 05:42 PM
NotStock's Avatar
For your setup, I would recommend our direct replacement bar. It comes with a Moog HD tie rod end that fits directly into your stock pitman arm instead of the Ballistic joint which requires drilling. It keeps all of your angles the same and gets you a MUCH stronger, tighter feeling steering wheel. The passenger, knuckle side tie rod end is reused. If you purchased the unit and were not happy with its performance, I would be willing to take it back and refund all of your money, less shipping expense as long as it was returned within 10 business days. If you have any questions, just let me know!
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #3 of 19 Old 01-28-2012, 08:20 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Oh I am sure I will love it. all your products are quality. How much is that setup?
08 F350 cc/sb 4X4
post #4 of 19 Old 01-28-2012, 03:44 PM
NotStock's Avatar
$400 plus the ride and I have 2 instock ready to ship.
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #5 of 19 Old 01-28-2012, 08:46 PM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Nice bro. Ill be calling you soon
08 F350 cc/sb 4X4
post #6 of 19 Old 08-28-2012, 03:00 PM
Quoted: 106 Post(s)
Feedback Score: 3 reviews
Did you ever get this installed? Do you have any pictures?
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS 2, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #7 of 19 Old 08-28-2012, 06:56 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I have one installed on my truck. It's the direct OEM replacement. I can get pictures tomorrow evening.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #8 of 19 Old 08-28-2012, 07:28 PM
Quoted: 106 Post(s)
That would be awesome. That is the same one would be getting. Did you have to drill the pitman arm or did it fit in directly?
post #9 of 19 Old 08-29-2012, 06:16 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
I will be installing mine next week. I got the direct replacement one so i wont have to drill the pitman arm.
08 F350 cc/sb 4X4
post #10 of 19 Old 08-29-2012, 11:49 AM
Quoted: 106 Post(s)
Did you order a new tie rod end for the passenger knuckle side?
