Changing Diff Cover and Fluid.
So I just rolled 100k On the truck last week and decided that I should change my diff fluid out once again (did it at 40k). In the process I am tired of taking the damn cover on and off so I am replacing the stock cover with a mag hytec. The questions is do you think I am fine to change the fluid if I havent changed it in 60k? Guy at a local show was trying to tell me not to do it. I think he is an idiot but still figured I would ask. Also what fluid are you guys using in the rear diff? I put ford fluid in it last time, but I would like to put a royal purple, or amsoil in it this time.
My buddy just swapped all his fluids to amsoil and loves it. Not sure I'm convinced you can really tell a difference but he swears by their products and from the research I've done they seem to be good. I actually have 4 gallons of their full synthetic 5w-40 oil out for delivery today. Expensive stuff but thought I'd give it a try and see how it goes. I may slowly make the full switch as well eventually.
I also don't see any reason why you couldn't change it yourself. But I'm sure someone more knowledgeable than myself will be along with a better info for you! |
Why in the hell would he say not to change it? Dont listen to him, change it out just make sure, as you already know, dont forget the friction modifier in the rear diff. And post up pics!!! I've been looking alot in the last week at the Mag units for the front and rear diff... I'd love to see it installed!
I got it changed out. The fluid in the rear diff was clean as could be. I put royal purple 75-140 in it. Took 6 qrts with the new pan. I asked the guy at napa about the friction modifier because I have always had to add it. He said that the royal purple doesnt need the friction modifier because it has it in it already. true? It looks great. I will get some pics taken later today and post up.
Here is a pic of the cover installed. Looks pretty good to me.
![]() Cover looks good! They are worth the upgrade....put it on my list
That cover looks great! Servicing is going to be 10x easier now. Fitment/quality was good? I've never had any first hand expirence with Mag's stuff.
Did you have to remove the sway bar during the installation? Did you do one for the front?
Yes fit and finish of Mag hytec products is GREAT! Ive always had one of there tranny pans on my trucks. This is the first diff cover I have ever gotten. You do not have to remove the sway bar to get it in. You can rotate it in from the top. The covers do not need any rtv sealant because they have a gasket built in so that was a HUGE plus. There is a dip stick in the top of the cover you can pull out to check fuild quality and level. Drain plug in the bottom, and peep hole screw you can take out of the middle to check fluid level as well. I did not do a front cover yet, it is on the list but they were back ordered when I ordered the rear. Anyone thinking about doing it, do it. Over all the swap took me about 40 min. Quick, easy, and will make fluid changes down the line easier.
Did your truck have the factory finned cover?
