I have h and s min max dpf delete pipes (still in box) and air kit and EGR block offs with coolant block offs . i would like to do full delete on EGR but im going to do block off 4 now but if i block off both do i hav to rush to do full delete ?? isnt it same just with cooler bloted on and block up and turnd off??
im thinking that too. this is my second 6.0. first one i did the whole thing. now im thinking of just capping off the egr cooler and letting the coolant flow. maybe even weld shut the t coming off the up pipe. would there be a need for that once a blocker flange has been put on either end of the cooler, or just one end.
IM THINKING OF DOING IT SOON I FIGURE IF ITS BLOCKD AND AT IF COOLANT IS REROUTD SHOULD B OK.
REROUT WATER LINES BECAUSE IF IT CRACKS IT LK IN
i guess for the money spent, its a no brainer. but why would it crack. the problem with the old coolers is that the coolant was not enough to cool the eg. thus causing it to boil and expand. would the problem be gone if you removed the eg. the only heat would be coming off the block. im pretty sure the welds can hold 16 psi. the plastic overflow cap can, so can the flimsy hose clamps.
O OK I DIDNT KNOW WHAT WAS UP WITH 6.0.. I THOUGHT FLOW WOULD B OK BUT PPL ACT AS IF 6.4 IS SAME.. I THINK PPL DO IT 4 PC OF MIND..
If it cracks, wouldn't it be better to have the coolant blocked off? That way the coolant doesn't go inside the engine.
Yes, block it off! It will save your hiney in the long run. |
| Tags |
| egr |
