Am I just over worries about my truck? - Ford Powerstroke Diesel Forum
Old 01-20-2012, 06:29 PM
Got the thing six months ago, deleted dpf and egr, got air intake, and installed mini max about a week ago. I drain the water seperator monthly and use diesel clean. I also put elc coolant in when I did egr delete, and I've been checking my coolant level daily bc I'm worried about coolant leak but no signs yet. Coolant just looks like its real low in the container, but it stays that low. Oil change every 5k and fuel filters every 10k. Should I be ok? Or am I too worried?
Sent from my Desire HD using AutoGuide.Com Free
Old 01-21-2012, 07:03 AM
It stays right below the full line? Mine does it to and i dont have any leaks so i just brushed it off. Guess i will be checking this thread for more info to
Old 01-21-2012, 07:21 AM
Your keeping an eye on things... not doing anything out of the ordinary? Carry on!
Old 01-21-2012, 07:29 AM
Mine is actualy pretty far below the cold fill line.
Old 01-21-2012, 07:36 AM
Just keep an eye on it. These trucks have lot of coolant in them and the level will normally vary.
Old 01-21-2012, 07:41 AM
When your truck is warmed up and coolant temp is around 180-190 where is the coolant at on the bottle?
Old 01-21-2012, 07:53 AM
so your coolant is low but you dont say if you have been adding any.
Old 01-21-2012, 07:56 AM
Should I be adding some? I'm just now coming to the conclusion that its low.
Old 01-21-2012, 10:45 AM
well,if you think it has dropped since you put in the elc.....that might just be due to air purging out..... i use a felt marker for where the coolant sits,so if it drops you can start looking.how much effort did you put in changing to elc...did you do the chemical flush and the whole nine yards?
Old 01-21-2012, 10:52 AM
Did do the chemical flush and let it run for a while till all chemical moved through system.
