How do you get EGR valve, off the elbow? - Ford Powerstroke Diesel Forum
Old 01-19-2012, 10:33 PM
Hi all had my 2008 f450 6.4 for 3 years now, current mileage 52k only changed a radiator twice, now EGR problems. How in blazes do you get that EGR valve off the plenum elbow? Anyone wanna buy my truck?lol
Old 01-20-2012, 02:45 AM
I think Ford has a special puller tool to get that thing off becuase they are usually damn near welded in. I've never actually pulled one out, I took the entire cooler out. Heard from a few people they are a major PITA though, you'll prob have to get a 2"x4" and a pry bar on it some how I would imagine. Good luck!
Old 01-20-2012, 01:05 PM
Powerstroke Techie
Feedback Score: 3 reviews
even the tool is a 50/50 shot at best, that's my sucess rate with it.
As a do-it-yourselfer just replace the elbow and egr together, no vertical cooler removal necessary, if you want I can give you good instructions on how this is done.
I snapped a pic of the last valve I broke off. Here's how the puller is situated
here's the broken valve
Old 01-28-2012, 11:21 AM
Hey thanks a bunch thats some good info and pics. I ended using a slide-hammer using the adaptor that joins a pair of vise grips on the end of the hammer. Removed the plastic housing and griped onto the end of the valve itself. With the plenum removed (just 4 bolts) Added some heat and (slide-hammering) and viola blew out like a honey-moon prick. LOL. I must say do not try and just pry and hammer out, this thing is really pressed into the elbow plenum, the casting just breaks off. F450 back on the Road!
Old 01-29-2012, 08:49 PM
Looks like a royal PITA. Would squirting in some Kroil before pulling help?
Any issues reinstalling?
Old 01-30-2012, 01:11 AM
'Merica
On the last 6.4 shop truck that had a stuck egr valve I had to pull the elbow off.
I just loosened the clamps securing the vertical cooler and finagled it out if the way.
And then proceeded to break the egr valve out in pieces. Also used some heat and lots of pb blaster. Didn't damage the elbow too bad at all. When I reassembled I used some scotch-brite pads and a nice coat of anti-seize.
Im not too fond of the egr valve setup on the 6.4s to be on honest.
