Coolant question - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-18-2012, 05:41 PM Thread Starter
acelay's Avatar
Coolant question
I am curious to see what the best coolent for this truck is or what are you guys using? Thanks
acelay is offline
post #2 of 21 Old 01-18-2012, 06:03 PM
Term3's Avatar
Any brand that says it is Cat EC-1 rated will do. You need 4 gallons of concentrated not the 50/50 premixed stuff. Napa sells Zerex ELC part # ZXED1.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 21 Old 01-18-2012, 06:23 PM Thread Starter
acelay's Avatar
Thanks....
acelay is offline
post #4 of 21 Old 01-18-2012, 06:39 PM
Galaxie's Avatar
When you swich over, be sure to do a full chemical flush.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 21 Old 01-19-2012, 05:49 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
this is what i used.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 21 Old 01-19-2012, 09:29 AM
Term3's Avatar
YES!!!!!!!!!
Term3 is offline
post #7 of 21 Old 01-21-2012, 12:04 PM Thread Starter
acelay's Avatar
I am sorry but what do you mean by switch over? Also what is a chemical flush.. I can't just add coolant?
acelay is offline
post #8 of 21 Old 01-21-2012, 12:05 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
if you just want to add coolant you need to put in Ford Gold assuming the truck still has ford gold in it
strokinpower is offline
post #9 of 21 Old 01-21-2012, 12:08 PM Thread Starter
acelay's Avatar
So basically by switch over he meant flushing the entire coolant? No mixutre of different brands? Will it cause a problem if I add something other than ford gold, not saying I will. Just don't understand
acelay is offline
post #10 of 21 Old 01-21-2012, 12:17 PM Thread Starter
acelay's Avatar
acelay is offline
