synthetic oil or not.. - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-05-2012, 08:36 AM Thread Starter
Oguck's Avatar
Smile synthetic oil or not..
Im new to this great machine. '09 F250 with 6.4L stock. owned it about 2 months now and it just turned 45k (oil was changed at 40k at the dealer).
I am looking to get input into the diffent types of oil. I live in Atlanta GA, so the coldest it gets in the winter is in the 20's (very rarely the teens, but I keep the truck in my garage anyway). during the summer it get upwards to 100F. I have always ran Mobil 1 synthetic in all my gas burners but don't know if its worth the money for my diesel. what has everyone out there done???
Thanks for any help.
Oguck is offline
post #2 of 19 Old 01-05-2012, 08:56 AM
dieselmatt's Avatar
Quoted: 4 Post(s)
I change my oil in my 6.0 every 5000 miles. I use synthetic now, but I used dino up to 100,000 miles. After switching my truck runs smoother and quieter. To me it is worth the extra money, but I'm running Shell Rotella T6 not the more expensive Mobil 1. In the long run it doesn't seem to matter too much as to which oil you run. The most important thing to keep up with your oil changes so you have fresh oil in there.
dieselmatt is offline
post #3 of 19 Old 01-05-2012, 09:02 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Its about personal preference. Seems like just as many guys on here run synthetic as run dino. I myself run dino and have no issues.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #4 of 19 Old 01-05-2012, 09:40 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
I run dino and im on the edge too...
Got 100k on my truck and i dont know what to do
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 19 Old 01-05-2012, 10:05 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
when i hit 100k on my 08, i switched from dino to Rotella 5w-40 full synthetic, and my truck loves it.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #6 of 19 Old 01-05-2012, 10:10 AM
mmandley's Avatar
I switched my 06 6.0 to T6 full syn at 50k and right away I got smoother starts, less rattle noise, and it sounded smoother at idle. Also on cold starts it was night and day difference with sound.
08 F350 6.4 Lariat CC LB tows a 13 Moomba Mojo 2.5
2inch Level kit
Mini Max tuner
S&B CAi
Diamond Eye 5inch exhaust straight pipe
HID headlights, and Fog lights
EGR delete <planned next>
Ladder bars <in the future>
mmandley is offline
post #7 of 19 Old 01-05-2012, 10:13 AM
Quoted: 370 Post(s)
Did you guys run syn blend through it first, or straight to the full syn?
Studded and Deleted
post #8 of 19 Old 01-05-2012, 10:17 AM
Thero's Avatar
Since you're not deleted I wouldn't even consider synthetic. Your oil changes will be way too frequent to justify putting that stuff in your engine...unless you have deep pockets that is.
I've been using Rotella 15w-40 but am coming up on my first oil change since deleting and will either change to Amsoil 5w-40 or the rotella T6 synthetic blend. Once deleted you'll be able to get more mileage out of your oil which will make it a little more affordable. I never drive more than 10k miles in a year so I'll likely go from 2 dino oil changes a year to just 1 with the synthetic.
__________________________________________
2008 F250 Lariat - CC / SB / 4x4
AFE Stage 2 Intake
Spartan (300EL DD)
AFE DP back 4" straight pipe w/ 6" tip
She finally gave it up after about 20 mins.
Thero is offline
post #9 of 19 Old 01-05-2012, 10:22 AM
Quoted: 14 Post(s)
good point, didnt know he wasnt deleted, you will not want to extend your oil changes to 10k miles if you are still running a DPF, your oil becomes diluted with fuel anyways so it really really needs to be changed at max 5k with DPF on
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #10 of 19 Old 01-05-2012, 10:25 AM
mmandley's Avatar
I went straight to full syn.
On the 6.0 it's imperative you change oil every 5k since the oil is used to fire the injectors and any dirt there uses injector issues such as sticking.
On the 6.4 it's an electric injector so it's not as important but I'm not sure the recommended oil change intervals. I was planning on going 5k intervals unless there is a more standard rate. I do all my own maintenance and fluid changes so full synthetic oil change is 100 not to bad. It would be 60 for regular oil so I have no problem paying the extra 40.
2inch Level kit
Mini Max tuner
S&B CAi
mmandley is offline
