truck shakes while towing gooseneck
hi i have a f240 cc sb with the spartan tunes I recently bought a 24 ft gooseneck trailer. i have noticed that when towing with a load on the trailer the car starts to shake not sure if its the motor or the trans has anyone had something similiar happen i have swicthed to the 150 to see if that makes any difference. any help or ideas would be apprecited thanks
are you talking a front to back surge that happens once and a while or a constant vibration?
It's not constant just when the truck is under load while going up grades or when I hitsleeds of around 73mph
how heavy is the trailer?
Thriller with Load Probably around 110000 lbs
My Guess without knowing how many miles or how hard they were is a Torque converter sudder/slipping or clutches startign to slip under load.
Change the Trans fluid and filter to start, and take a look at the fluid coming out (burnt is not a good sign, nor is seeing particles in the fluid). |
it could also be axel wrap
You probably shouldn't be towing 110,000 lbs.
You're truck is just telling you it's pissed..
Light vibrations or is the truck surging?
