coolant flush info - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-27-2011, 12:20 PM Thread Starter
bentstroke_02's Avatar
coolant flush info
Okay so i have searched on here and googled this and i have found alot of info but there are still a few questions i have. I am getting close to 200k on my truck and i want to flush and install a coolant filter. I have seen that flushing can cause the oil cooler to clog and i sure in the Heck dont want that to happen. So here are my questions.
Has anyone done a coolant flush and afterwards had the oil cooler get clogged?
Should i install the filter before or after the flush?
How do you do a coolant flush on a 6.4?
Can i switch to Cat elc?
While im installing the coolant filter should i do the egr delete to? (not to sure if this has anything to do with coolant)
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #2 of 8 Old 12-27-2011, 01:09 PM
reighnman's Avatar
Installing the coolant filter before the flush would be helpful, just expect to change in a new filter after the flush so order an extra.
With a proper flush you can switch to elc, just be sure to flush the system properly with restore/restore+. From another thread:
"The restore is to remove the coating that the stock coolant deposits onthe walls of the cooling system to help stop cavitation issues.
The restore+ is to remove rust scale build up in the system. You can use Ford VC-9 in place of the restore+ (you will need 2 quarts), there is no substitute that I know of for the restore product.
If you were to skip the restore, the elc style coolant could react chemically with the coating from the existing coolant, since it is a very different type and style.
If you were to skip the restore+, you would be leaving the rust scale in the cooling system. "
To do a proper flush takes takes a long long time, with several flush, run for an hour, flush, run for an hour, flush, run for an hour, flush etc. so put aside a full day and buy a ton of distilled water. You'll also need to catch the initial coolant + other chemicals so you'll need a large container (drum) to properly dispose of the fluids. There are several write-ups on doing proper coolant flushes.
Black 2008 F250 Lariat 4x4 6.4L CC Job3, DPF/DOC Delete, H&S mini maxx, S&B Intake, vista-pro radiator
Black 2010 Mitsubishi Evolution, UR, AMS
reighnman is offline
post #3 of 8 Old 12-27-2011, 06:24 PM Thread Starter
I did read over this when i did my search and this is what scares me for clogging the oil cooler. Im going to go ahead and do it and hope for the best. I have kept researching even after this post and im going to order my coolant filter and 2 filters along with my egr delete and do those first before i do my flush. Now i still have two questions that should be easy to answer i think.
Can i run the Cat elc and what mixture?
How do you do a proper flush?
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
post #4 of 8 Old 12-28-2011, 06:56 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
i read those other flush posts also, i think the possible oil cooler clogging issue was if a flush machine was used.....this method is draining , filling, running , draining a bunch of times...
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
post #5 of 8 Old 12-29-2011, 05:40 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i did a flush with VC9 and a bunch of distilled water. I used ELC coolant and i used a 50/50 mix. Make sure you get the concentrate coolant and not the 50/50 mix.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 8 Old 12-29-2011, 05:44 AM
2003kingranch's Avatar
heres my flush for a 6.0. should still apply
Did Coolant Flush Today / writeup
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #7 of 8 Old 12-29-2011, 05:52 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
awesome write up thx
post #8 of 8 Old 12-29-2011, 06:11 AM Thread Starter
Would that work for a 6.4? I believe i have read this.
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
