Oil in the bottom of CAC - Normal? - Ford Powerstroke Diesel Forum
Old 12-19-2011, 04:51 PM
I have a small leak of oil at the bottom of the lower end of the Charge Air Cooler where the rubber connection is. Is it normal to have some oil there?
Old 12-22-2011, 12:00 PM
Take a look at your intake tube... see that rubber hose that goes from the oil fill neck to the intake tube, thats your problem. If you do a CCV mod this will eliminate the oil in your CAC. They all have "some" oil in the CAC with the factory set up, its normal.
