Ball joints - Ford Powerstroke Diesel Forum
Old 12-14-2011, 03:39 PM
Ball joints
Replacing ball joints in my 08 f350 4x4 having hard time getting axle shaft seal out any ideas to get it out thanks in advance
Sent from my PG86100 using AutoGuide App
Old 12-14-2011, 03:44 PM
Illiana Chapter Director
I turn the wheel and get a pry bar on the axle shaft at the u-joint and pry against the axle tube which pushes it out.
Old 12-15-2011, 05:13 AM
Which ball joints did you go with? Also is there anything else one should do while there besides u-joints? Axle seals or anything?
Old 12-15-2011, 09:07 AM
There is a vacuum seal and 2 o-rings on each side that have to be replaced.
Old 12-15-2011, 11:00 AM
thanks! I will do those when i do my ball joints and u-joints
