Coolant filtration benefits - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-12-2011, 08:00 AM Thread Starter
chihuahuaford's Avatar
Send a message via MSN to chihuahuaford
Have a couple of question
Seems like everyone after 100k r starting to have egr and coolant problems
What r the benefits of a coolant filtration system?
What the diffrence between the cheap egr ($200) to the expensive one?
08 King Ranch f-250 Cat/DPF Delete Job 1 Spartan Phalanx Flash Console, 250 tune 325/60/20 Nitto Terra Grappler Stock Wheels!
08 King Ranch F-250 Cat/DPF Delete Job 3 Spartan Phalanx Flash Console, 275 tune 325/60/20 BFG Mud Terrain KM 2
09 King Ranch F-450 Cat/DPF Delete Spartan Phalanx Flash Console, 275 tune Front Leveling kit 22.5 Pete Style Alcoas with 37" Goodyear tires(16 ply)
chihuahuaford is offline
post #2 of 3 Old 12-12-2011, 08:43 AM
srjd's Avatar
Quoted: 2 Post(s)
I think its best to run a filter if you have the stock ford gold coolant..I am putting my filter on this week going to try and filter out as much of the junk that gold coolant makes before i do a flush and risk clogging my oil cooler which can lead to really big problems. I believe the difference is one is just block off plates and the other is a complete delete getting rid of the coolers all together. Dont qoute me on that I could be wront im sure someone else will chime in with a more specific answer...for the time being I hope this helps
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 3 Old 12-12-2011, 11:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i think a coolant filter is a good idea. Attached is a picture of my coolant filter before i did a chemical flush. Also if you are doing an egr delete you might as well go all out and get the better flowing intake elbow.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
