Getting My New 6.4!!!!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-11-2011, 07:52 PM Thread Starter
AL350stroker's Avatar
Hey guys I'm going tomorrow to buy a 2008 f250 king ranch with 6 inch lift. I'm just wondering if there is anything I need to watch out for/ replace before it breaks besides the egr delete and dpf delete?? Also what's best for the truck as far as performance and upgrading goes??
Thanks for the help
AL350stroker is offline
post #2 of 9 Old 12-11-2011, 08:07 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
Congrats on the new truck! The oil cooler and the radiator/hoses seem to be weak points for these trucks. The EGR delete will give you reliability and longevity and the DPF delete will give you better fuel mileage and more power.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 9 Old 12-12-2011, 06:06 AM
Look for any coolant leaking underneath the engine,also look for any other mods besides the lift,intake,exhaust,tuner,to make sure you know what you are getting into...enjoy I love mine!
EVERYDAY J is offline
post #4 of 9 Old 12-12-2011, 07:03 AM
Hooked on the POWER...
allenhood71's Avatar
Feedback Score: 6 reviews
Also ask if the fuels filters have been changed per ford specs. And if the water seperator has also been drained regularly. I bought the same truck about 4 months ago with 22,000 miles on it and it is at ford right now getting a new motor on my dollar($15,000) because of "lack of maintnance" on the previous owners part. The high pressure fuel pump was rusted and sent debris to the injectors past the filters and hung one of them open and melted a piston. Just a heads up....
allenhood71 is offline
post #5 of 9 Old 12-12-2011, 07:30 AM
smotrs's Avatar
Congrats on the new ride. Make sure all the TSB's have been done. Normal maintenance is a must. As mentioned before, regularly draining the water separator, radiators tend to split around where it mounts on some trucks and hoses can leak over time due to a single o-ring design which was later changed to a dual o-ring design.
Even if your planning on a DPF/CAT delete, keep in find, fuel dilution can still occur if you perform allot of short trips that don't get the vehicle properly warmed up. These trucks prefer highway travel and towing more then city drivintg. If your looking for a grocery getter, you should take a look at a Humvee instead.
Shaun
'08 F250 6.4L Lariat 4x4 CC/SRW fully loaded, special ordered
6" Fabtech 2.25 dual shock lift w/18" AR wheels, 35" Toyo AT's
Avic-Z2 Nav/Stereo w/iPod, Bluetooth, XM NavTraffic
(2) Rear headrest mnt DVD entertainment systems
Line-X bedliner
Banks CAI, Dual Exhaust, Six-Gun, Speed Brake & iQ (test vehicle)
Bushwacker Fender Flares
Ravelco Anti Theft Device
Originally Posted by Rick Santorum
We went into a recession in 2008 because of gasoline prices.
smotrs is offline
post #6 of 9 Old 12-12-2011, 10:09 AM Thread Starter
Thanks guys ill def look at all that and keep that in mind. It's coming from a Ford dealership and is a 1 owner truck that was bought at that dealership and traded back in there with all the service records. I'm hoping its a good truck and from what I've seen so far it should be. Does anyone have any upgrades for the truck extra u might wanna sell??
post #7 of 9 Old 01-16-2012, 12:37 PM
f350powerstroke's Avatar
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #8 of 9 Old 01-16-2012, 02:14 PM
acelay's Avatar
Check underneath for an oil leak! Have had mine for 3 weeks and is at the dealer for warranty fix. :-(
acelay is offline
post #9 of 9 Old 01-16-2012, 03:26 PM
i change my fuel filters every 10k miles !!!
-Mike-
2006 F-350 Lariat, Supercab, 6.0L, 3.73's...Rhinolined Bed...6 Spd Handshaker...Mag-Hytec Diff. Covers...Smoked Recon Lights...Amsoil oils front 2 back...Optima Yellow Tops...MBRP 5" ST8 Pipe, Turbo Back...Dieselsite Coolant Filter...Amsoil/Injen CAI...SCT SF3 Canned Tunes 4 Now...CFM Intake Manifold and Boost Tube...Blue Spring Upgrade...Edge Insite CTS !!!
pete37922 is offline
