Towing Heavy!
Hey Guys,
I got a 2008 Ford F250 6.4l Diesel and I'm gonna be towing around 15k total from Mass-NJ. About a 3 hour ride. The trailer is a gooseneck and I'm wondering how my f250 is going to like the weight. What should i do to make it better. (if anything) tips and advice is appreciated. Thanks guys. Tom |
I can't speak for the 6.4 specifically but add some airbags and check the brakes on the truck and trailer thoroughly.
Thanks for the info... I know my truck is going to be illegal towing it... Should i still do it? What are the risk of getting caught. Any advice guys would be helpful... This is a gooseneck
If your truck is illegal towing it, short answer is no, you shouldn't tow it. As for risks of getting caught, I'm not sure about where you're driving but here, because of the Christmas season, the police have started to do daytime Check Stops several times a week in addition to evening Check Stops. If you get stopped/pulled over at one of these and there is a cop or DOT officer that knows the rules, you can be screwed. If you can, maybe split the load up into two trips to stay legal.
Tom |
https://www.fleet.ford.com/showroom/...trp19Aug07.pdf
This says I'm aloud to tow 15,200? If so then I'm just a tad under, or dead even... Correct? Tom |
the way i understand it.....if they think you look overweight and want to check you they will have a set of scales or send you to a set of scales. as long as your truck tires are E rated [like 3400lbs each] and your truck axle rating is not over exceeded i think you will be fine....think the F250 HAS 6800lb axles ....the p.i.n. wt. on the goosenek ball is what counts...plus of course the trailer cant be overloaded.
Thanks guys Tom |
