Aux Tank - Ford Powerstroke Diesel Forum
Old 12-08-2011, 12:00 PM
Aux Tank
I've looked over several topics here on installing an aux tank in the bed to gain additional fuel capacity. Many provide great tips and ideas. The question I have is has anyone found a good electric shut-off solenoid to use with an upfitter switch? I purchased one for my installation and the flow rate is less than what I was looking for. Yea, it flows...I pulled the fuel line off the cutoff valve to check. Any suggested item manufactor and number, source, etc. will be much appreciated.
Old 12-09-2011, 07:23 AM
have you looked at titan fuel tanks? no need to take up bed space. A buddy of mine has one and loves it
Old 12-09-2011, 06:21 PM
Yes I did. I found it cost prohibitive for my application. The aux tank will work well if I can get the flow rate that I am looking for. Thanks.
Old 12-09-2011, 06:30 PM
I had a trickle tank in the bed of my truck and it always flowed so slowly that when I started to dump fuel from it into my main tank, when I had a 1/4 of a tank left in my main tank, I'd easily run out of fuel. Eventually replaced that pump with a dual filter/nozzle configuration and would just pull off into a roadside turnout/rest stop to quickly refuel. Worked way better and I had two fuel filters to filter the diesel so I could keep it in the tank longer with minimal worries about water or other contaminants getting into my truck's fuel system without having to add any additives.
Old 12-10-2011, 03:42 PM
I have the Transfer Flow 40 gal tool box, fuel combo, has worked flawlessly for 4 years now, it keeps the aux tank and stock tank at same level and your stock fuel gauge is accurate. for example if you your cluster fuel gauge says 1/2 full, that means there is half tank in your stock tank and half in your aux tank, works great. Love the range, one of my best mods
Old 12-10-2011, 03:45 PM
Thanks for the advise. Adding a pump may be the best approach. I'll also look into the Transfer Flow units.
Old 12-10-2011, 04:40 PM
Do you have their electronic gauge, the Trax II? Also, any pictures of the setup? Would like to get a new transfer tank, one that would fit under a hard top tonneau and the 50 gallon tank does that but also like the idea of a tank/toolbox combo.
Old 12-10-2011, 04:48 PM
Powerstroke Techie
Upfitter switches 1 and 2 are fused for 30 amps. #3 and 4 have a 10 amp fuse. I couldn't imagine a fuel pump drawing more than that. So there is no need for a relay or a solenoid for the pump.
Old 12-10-2011, 05:09 PM
Yes sir, I do have the Trax II. No pics because I am deployed at this time. The tank fits about 3/4" lower then the bed rails. Works flawlessly.
