Just Curious - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-06-2011, 10:13 PM Thread Starter
BigGreen06's Avatar
Quoted: 105 Post(s)
Just Curious
What is the normal operating temp for the Engine Oil and the Coolant?
My thoughts are that my EOT doesn't seem to budge above or below 90* when up to temp, lately been 60 during the day and 35-40 at night. The ECT seems to stay around 190*-192* normal city driving, and on the highway it jumps to 196* and at times will go up to 200* if I'm heavy into the throttle, but I try to stay out of it.
Just want to take care of things if I have a potential problem starting here.
Thanks Guys.
James.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 7 Old 12-06-2011, 11:16 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
what are you using to check eot? It should be around 5 degrees warmer than the ect cruising, and after idling a while dead even. Sounds like either the sending unit is bad, or if you're using a scangauge, it's using the wrong PID.
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #3 of 7 Old 12-07-2011, 12:24 AM Thread Starter
BigGreen06's Avatar
Quoted: 105 Post(s)
SCT Livewire. Pretty sure there is only one PID for the EOT.
James.
Accufab Elbow
LineX in the Bed
post #4 of 7 Old 12-07-2011, 05:22 AM
strokin07's Avatar
SCT uses "CELSIUS" to display engine oil temp. Which would make that 194 degrees Fahrenheit. This is probably the third post I have replied to in two weeks about this.
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #5 of 7 Old 12-07-2011, 06:21 AM
Quoted: 2 Post(s)
what he said... i just asked this same question about a week ago
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #6 of 7 Old 01-08-2012, 10:48 PM
wontonrunner's Avatar
Those are pretty much the same numbers i got when I ran some tests back in October.
My Little Truck
2008 F350 FX4 Superduty Fully Loaded
6" Frankenstein Lift
20" Jessie James Rims
35" Toyo MT
Chrome Steps and Box Rails
Jackrabbit Sliding Bedcover
Eclipse Navigation/DVD with Rear TV's
SCT9625OR , Powerstroker67 DPF/DOC and 4" MBRP
My Big Truck
1991 Toyota 4runner
Solid Axle Swap
19" over Stock using F150 leaf springs
D60 Front 14BFF Rear
Detroit Locker up front, Mini Spool in the rear
39.5" TSL on Custom Hummer Beadlocks
Custom Baha Fenders
wontonrunner is offline
post #7 of 7 Old 01-09-2012, 05:07 AM
mmandley's Avatar
on my 6.0 ECT was almost always low to mid 180s and EOT was 7 to 10 above that.
6.4 ECT stays right around 190 all the time and EOT is almost always 0 to 2 degrees different.
08 F350 6.4 Lariat CC LB tows a 13 Moomba Mojo 2.5
2inch Level kit
Mini Max tuner
S&B CAi
Diamond Eye 5inch exhaust straight pipe
HID headlights, and Fog lights
EGR delete <planned next>
Ladder bars <in the future>
mmandley is offline
