Adding Tailgate Marker Lights - Ford Powerstroke Diesel Forum
post #1 of 29 Old 12-05-2011, 07:22 AM Thread Starter
cp2146's Avatar
I've got this thread going in Exterior Discussion as well, but I wanted to throw it to a larger audience for ideas.
I'm thinking about adding the tailgate marker lights. The mounting holes are already there so the initial installation will be easy, but I'm wondering which would be the best source for power and the best way to route the wiring. The taillights themselves seem the obvious choice, but the license plate lights are closer...or perhaps the trailer light plug harness. Anyone else ever done this? I'm sure I could jury rig something, but I want to do it right and make it look good (the wiring, that is). All suggestions welcomed and appreciated.
Wayne
Wayne
2008 F350 Lariat 4X2 CC 6.4L
dark blue over grey
totally stock and love it that way
cp2146 is offline
post #2 of 29 Old 12-05-2011, 04:47 PM
I'm confused, where are the lights going to go?
Jimbo33 is offline
post #3 of 29 Old 12-05-2011, 04:52 PM Thread Starter
cp2146's Avatar
The red marker light bar that goes on the strip just under the tailgate, right above the license plate. They are usually found on the F450 dually.
Wayne
dark blue over grey
cp2146 is offline
post #4 of 29 Old 12-05-2011, 04:59 PM
Diesel Addict's Avatar
I wired mine to the tag lights, when Ford wires them from them from the factory on the duallies they are wired into the tag light harness. Good luck with the install, you'll be glad you installed them!
2006 F-350 CCLB
6-Speed Manual
6" Fabtech Lift, looking to go a few inches shorter and higher quality
35" Toyo Open Country MT's
AFE stage 2
MBRP 4" turbo back straight pipe
SCT Livewire tunes by Eric
Studded and deleted
The right to keep and bear arms SHALL NOT BE INFRINGED!
Diesel Addict is offline
post #5 of 29 Old 12-05-2011, 05:07 PM
I put those lights on my old truck and wired to the tail lights, and I want to put them on this truck, what type of light bar are you using?
Jimbo33 is offline
post #6 of 29 Old 12-05-2011, 05:17 PM Thread Starter
cp2146's Avatar
Thanks, Diesel Addict, that actually tells me what I need to know. One other question, though. Does the wiring for the light strip come out the back and go through another hole (didn't see one, just the two mounting holes), or is it exposed down the front then on to the tag lights? I know I'll find out for myself soon enough, but I'm just trying to get an idea what I'm dealing with before I start the project.
Wayne
dark blue over grey
cp2146 is offline
post #7 of 29 Old 12-05-2011, 05:18 PM Thread Starter
cp2146's Avatar
I'm planning on using the OEM lights from Ford.
Wayne
dark blue over grey
cp2146 is offline
post #8 of 29 Old 12-05-2011, 05:24 PM
Okay, Cause I know they sell led ones, but unless everything else were led's it might look cheesy, So the tag lights will suppose enough power for the lights?
Jimbo33 is offline
post #9 of 29 Old 12-05-2011, 05:35 PM Thread Starter
cp2146's Avatar
I agree, but since they'll be OEM for a 2008, I assume they'll be regular bulbs and not LED's. According to Diesel Addict, that's where Ford wires them from the factory.
Wayne
dark blue over grey
cp2146 is offline
post #10 of 29 Old 12-05-2011, 05:36 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Wire them to the tags or tails
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
