Rear Calipers - Ford Powerstroke Diesel Forum
Old 12-01-2011, 08:49 PM
To Many Projects
Rear Calipers
Any one Have problems with there rear calipers I'm on my fourth driver side one and two pass. Thankfully Ford has eaten all of them so far.
Old 12-02-2011, 04:12 PM
I did. Right rear was dragging, ruined rotor. Good thing was my mileage has improved since repair.
Old 12-02-2011, 07:03 PM
To Many Projects
maybe it will help mine
Old 12-02-2011, 07:05 PM
Powerstroke Techie
The superdutys have had issues with sticking calipers. All the way from the 99's to the 09's I haven't touched much newer than that for brakes yet.
Old 12-02-2011, 07:09 PM
To Many Projects
I kind of figerd it was a SD problem since I have had ti work on them on my X too.
Old 12-02-2011, 07:12 PM
Powerstroke Techie
I got one truck that I service on the side that has had every caliper on it replaced and I've had one of the new ones stick too. It's sad cause sometimes they push in normally but they smoke the new pads off of that corner in a few thousand miles.
Old 12-02-2011, 07:15 PM
To Many Projects
I know what you mean the way it's set just dosen't work well for long.
Old 12-03-2011, 04:08 AM
Actually, the previous owner changed changed the same caliper at 30k. I did at 60k. I will see if i make it past 90k.
Old 12-04-2011, 12:18 AM
To Many Projects
Well I hope for you it dose
Old 12-04-2011, 03:29 AM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
If you grease the slides/pistons then usually they wont go bad. I smoked one on my last truck, keep everything greased after that, and never had an issue again. You notice this happening more in the snow belt states where salt and grime can get in and ruin them.
